29 October 2026, 10:54:30
For the past 24 hours: 89 objects added, 103 objects edited, 12 objects removed.
КОРДОН-М 4 (тыл)
24 June 2015, 10:08:15
24 June 2015, 15:56:39
andrej260276, changed speed limit from 80 to 90.
andrej260276, changed warning direction type from Two directions to All directions (360).
andrej260276, confirmed object added via Mapcam.info program
24 June 2015, 18:04:55
Ознакомиться обязательно: Справка.
Укажите тип камеры в описании объекта, уберите круговое оповещение.
24 June 2015, 18:40:06
silandser, changed warning direction type from All directions (360) to Two directions.
24 June 2015, 18:40:33
Присоединясь к вопросам выше
22 October 2015, 17:58:50
Иногда стоит тринога в отбойнике но очень редко
22 October 2015, 18:36:27
Не стационар. До подтверждения или удаления -1
06 March 2016, 15:15:25
Приблизительно тут висит муляж.
06 March 2016, 15:16:30
Hyundi505, changed object description from 'Объект добавлен с помощью программы MapcamDroid (on-line)' to 'Муляж. Рейтинг ноль.'.
23 April 2016, 13:18:42
там муляж облезлый -1
23 April 2016, 13:23:25
Муляжи держим с рейтингом 0. Вернитп точке плюс
24 April 2016, 05:54:08
см.выше. +1
15 July 2016, 14:55:05
Koten, changed object latitude from 39.941614 to 39.940048
Koten, changed object longitude from 54.503691 to 54.503753
Koten, changed object description from 'Муляж. Рейтинг ноль.' to 'Кордон'.
15 July 2016, 14:56:34
Кордон повесили. +1
24 July 2016, 13:34:07
Господа а где фотографии то?
14 August 2016, 06:39:06
Муляж висит по направлению "на Москву", по направлению "из Москвы" висит стационар +1
27 November 2016, 11:12:12
Hyundi505, changed object latitude from 39.940048 to 39.939669
Hyundi505, changed object longitude from 54.503753 to 54.503872
Hyundi505, changed object type from  Static speed camera Static speed camera to   .
Hyundi505, changed warning direction from 100 to 99.
Hyundi505, changed object notification distance from 500 to 300.
Hyundi505, changed object description from 'Кордон' to 'Кордон-М2'.
27 November 2016, 11:12:45
27 November 2016, 11:13:01
27 November 2016, 11:14:02
Какие будут мысли. есть смысл добавлять вторую точку по направлению из Рязани? Кордон могут настроить по левым полосам...
25 January 2017, 16:38:09
камеру перевесили на противоположную сторону снимает поток из рязани -1
25 January 2017, 16:45:28
А зачем минусовать? Дайте фотографию или координаты опоры....
25 January 2017, 16:47:01
Ха, так Вы свою точку поставили....Так на проекте не принято. Удаляйте свою точку а эту подвинем туда, не ждите минусов, сейчас завалят...
25 January 2017, 17:26:42
передвигайте. объект не верный. свой удалил.
25 January 2017, 17:29:00
Она так же в спину или в лоб работает?
25 January 2017, 17:32:45
У Вас самих карма позволяет исправить чужие точки.
25 January 2017, 18:08:09
Hyundi505, changed object latitude from 39.939669 to 39.937765
Hyundi505, changed object longitude from 54.503872 to 54.503925
Hyundi505, changed object type from   to  Static speed camera Static speed camera.
Hyundi505, changed warning direction from 99 to 280.
Hyundi505, changed object notification distance from 300 to 650.
25 January 2017, 18:09:21
hempler, Вы тут часто бываете? Комплекс смотрит в тыл или лицо? Поправил точку, необходимо подтверждение!
25 January 2017, 18:10:50
Hyundi505, changed object description from 'Кордон-М2' to 'КОРДОН-М2'.
01 May 2017, 10:55:25
Koten, changed control area.
Koten, changed object type from  Static speed camera Static speed camera to   .
Koten, changed object notification distance from 650 to 469.
01 May 2017, 10:57:07
Камера смотрит от Рязани (т.е. в хвост едущим в область).
01 May 2017, 11:31:17
maykl3011, changed warning direction from 280 to 279.
maykl3011, changed object notification distance from 469 to 400.
13 May 2017, 20:05:07
19 June 2018, 04:46:53
19 June 2018, 04:47:20
pupok, changed control area.
pupok, changed camera model.
19 June 2018, 04:48:05
pupok, changed object description from 'КОРДОН-М2' to 'КОРДОН-М2 [212км 630м]'.
19 June 2018, 05:22:25
Подтверждено штрафом +1
22 July 2018, 08:22:40
прохоров, changed object latitude from 39.937765 to 39.939868
прохоров, changed object longitude from 54.503925 to 54.503799
прохоров, changed object description from 'КОРДОН-М2 [212км 630м]' to 'КОРДОН-М 2 (в спину) [212км 630м]'.
22 July 2018, 08:26:22
Подкорректировал обе точки - ориентировался по координатам в свежих штрафах за 2018 год и по расстоянию от столбика "213"
22 July 2018, 13:01:49
maykl3011, changed object latitude from 39.939868 to 39.939900
maykl3011, changed object longitude from 54.503799 to 54.503762
22 July 2018, 13:03:27
maykl3011, changed object latitude from 39.939900 to 39.939895
maykl3011, changed object longitude from 54.503762 to 54.503749
22 July 2018, 13:03:58
Поставил на середину дороги.
25 September 2018, 19:35:44
06 October 2018, 12:59:33
03 April 2023, 18:58:07
Демонтирован сюда? https://mapcam.info/speedcam/point.php?idm=5rLYqORpxie -1
03 April 2023, 18:58:15
Демонтирован -1
03 April 2023, 18:58:28
Демонтирован https://mapcam.info/speedcam/point.php?idm=5rLYqORpxie сюда? -1
04 April 2023, 07:10:44
Выше -1
04 April 2023, 07:10:49
Выше -1
04 April 2023, 07:10:54
Выше -1
12 July 2023, 09:00:39
выше -1
12 July 2023, 09:00:47
выше -1
12 July 2023, 09:00:53
выше -1
25 October 2023, 15:47:43
25 October 2023, 15:48:37
Поправьте камеру, пожалуйста. А то у меня криво получается )
25 October 2023, 17:01:18
С другой стороны есть или эта и в спину контролирует?
Фото нет случайно?
25 October 2023, 19:05:19
Думаю завтра штраф прилетит за обратный путь. Отпишусь.
28 October 2023, 12:36:04
не пришел
25 October 2023, 17:02:35
В какую сторону ехали?
25 October 2023, 19:04:41
Ехал из Рязани
25 October 2023, 16:12:09
УльяновскGSM, changed control direction from In the back to Counter direction.
УльяновскGSM, changed object description from 'КОРДОН-М 2 (в спину) [212км 630м]' to 'КОРДОН-М 2 [212км 570м]'.
25 October 2023, 16:12:20
УльяновскGSM, changed object latitude from 39.939895 to 39.939626
УльяновскGSM, changed object longitude from 54.503749 to 54.503784
25 October 2023, 16:12:39
Актуализация, подтверждено штрафом +1
25 October 2023, 16:12:42
25 October 2023, 16:12:47
25 October 2023, 16:58:40
выше +1
25 October 2023, 16:58:45
выше +1
25 October 2023, 16:58:50
выше +1
25 October 2023, 19:06:59
штраф +1
25 October 2023, 19:07:21
штраф +1
15 August 2024, 10:02:08
Камеру развернули. просьба скорректировать направление контроля
20 August 2024, 13:49:39
фото нет?
20 August 2024, 13:50:13
, changed object description from 'КОРДОН-М 2 [212км 570м]' to 'КОРДОН-М 2 (тыл) [212км 570м]'.
26 August 2024, 21:15:59
26 August 2024, 21:16:19
26 August 2024, 21:16:23
26 August 2024, 21:16:26
27 August 2024, 10:52:24
Выше -1
27 August 2024, 10:52:28
Выше -1
27 August 2024, 10:52:32
Выше -1
27 August 2024, 11:37:26
удалено -1
02 April 2025, 12:27:36
02 April 2025, 12:27:46
25 March 2026, 16:02:21
, changed object latitude from 39.939627 to 39.938853
, changed object longitude from 54.503784 to 54.503930
, changed warning direction from 279 to 99.
, changed object notification distance from 100 to 400.
, changed object description from 'КОРДОН-М 2 (тыл) [212км 570м]' to 'КОРДОН-М 4 (тыл)'.
25 March 2026, 16:02:55
новая, нужен рейтинг 1 +1
25 March 2026, 16:03:00
25 March 2026, 16:03:04
25 March 2026, 16:03:27
26 March 2026, 06:43:46
Рейтинг 1 +1
26 March 2026, 06:43:49
Рейтинг 1 +1
26 March 2026, 06:43:52
Рейтинг 1 +1
