22 October 2026, 03:51:13
Архив
07 October 2009, 15:23:02
08 October 2009, 15:25:09
29 October 2009, 21:27:21
10 July 2010, 18:38:09
alexdrive, changed warning direction type from All directions (360) to Two directions.
alexdrive, changed warning direction from 0 to 132.
18 September 2010, 17:55:55
15 May 2011, 15:02:05
Заяц, changed object type from  Portable Camera (trap) Portable Camera (trap) to  Regular police post Regular police post.
Заяц, changed object description from 'Пост' to 'Стационарный пост ДПС'.
15 May 2011, 15:02:42
скорость 40 или 50?
14 June 2011, 16:29:44
есть такой
29 November 2011, 09:39:57
, changed object latitude from 39.785829 to 39.785700
, changed object longitude from 59.242800 to 59.242888
, changed warning direction from 132 to 135.
, changed object notification distance from 500 to 681.
29 November 2011, 09:44:06
, changed object latitude from 39.785700 to 39.785700
, changed speed limit from 50 to 40.
07 June 2012, 17:44:02
, changed object latitude from 39.785700 to 39.785796
07 June 2012, 17:44:03
, changed object longitude from 59.242888 to 59.242740
, changed object notification distance from 681 to 550.
07 June 2012, 17:44:24
, changed object latitude from 39.785796 to 39.785797
07 June 2012, 17:45:22
Поправил местоположение
07 June 2012, 18:50:23
, changed object latitude from 39.785797 to 39.785797
26 October 2013, 07:08:26
ПОПРАВЬТЕ. СКОРОСТЬ НА ДАННОМ УЧАСТКЕ 60
03 November 2013, 07:15:24
скорость 60... большой напряг когда скорость не правильно выставлена откорректируйте, не первый раз прошу. -1
03 November 2013, 17:31:14
stroy82, changed speed limit from 40 to 60.
03 November 2013, 17:31:47
Исправил по просьбе.
26 March 2017, 18:50:25
Дадада +1
10 February 2020, 16:01:42
Знак города перенеси к Тошне, здесь скорость изменится?
04 April 2020, 18:22:30
Survey_19, changed warning direction from 135 to 133.
Survey_19, changed object notification distance from 550 to 250.
01 September 2024, 22:40:25
нет поста -1
01 September 2024, 22:40:27
нет поста -1
01 September 2024, 22:40:29
нет поста -1
02 September 2024, 02:07:34
, changed object type from  Regular police post Regular police post to  Other danger Other danger.
02 September 2024, 02:07:57
, changed warning direction from 133 to 139.
02 September 2024, 02:08:34
02 September 2024, 02:08:44
02 September 2024, 02:08:50
02 September 2024, 07:47:21
По просьбе -1
02 September 2024, 07:47:26
По просьбе -1
02 September 2024, 07:47:30
По просьбе -1
02 September 2024, 08:19:03
Выше -1
02 September 2024, 08:19:06
Выше -1
02 September 2024, 08:19:09
Выше -1
02 September 2024, 10:45:35
Говорят нету -1
02 September 2024, 10:45:43
Говорят нету -1
02 September 2024, 10:45:48
Говорят нету -1
02 September 2024, 10:56:01
и показывают...))
03 September 2024, 18:36:03
Виноват, извиняюсь не был внимателен.
02 September 2024, 12:46:17
Отсутствует -1
02 September 2024, 12:46:21
Отсутствует -1
02 September 2024, 12:46:23
Отсутствует -1
02 September 2024, 13:29:59
удалил -1
02 September 2024, 13:30:01
удалил -1
02 September 2024, 13:30:03
удалил -1
02 September 2024, 13:33:34
, changed object description from 'Стационарный пост ДПС' to 'Архив '.
