23 October 2026, 06:38:09
For the past 24 hours: 54 objects added, 88 objects edited, 20 objects removed.
КОРДОН-М2 (в спину) [190км 322м]
16 July 2019, 12:08:49
16 July 2019, 13:24:16
djmalov, changed speed limit from 0 to 50.
djmalov, confirmed object added via Mapcam.info program
02 November 2019, 15:00:42
А что это?
20 December 2019, 09:33:40
Видел на столбе КордонМ-4. Смотрела в сторону Куйбышевского шоссе. Ограничение вроде 60, но это не точно...
20 December 2019, 09:35:26
motor62, changed object description from 'Объект добавлен с помощью программы MapcamDroid (on-line)' to 'Кордон-М 4'.
20 December 2019, 09:37:00
motor62, changed object latitude from 39.660925 to 39.661000
motor62, changed object longitude from 54.597312 to 54.597378
motor62, changed warning direction from 294 to 296.
20 December 2019, 09:49:11
motor62, changed object latitude from 39.661000 to 39.657480
motor62, changed object longitude from 54.597378 to 54.598349
20 December 2019, 14:17:02
kenalog, changed object description from 'Кордон-М 4' to 'КОРДОН-М 4 (в спину)'.
02 February 2020, 09:48:26
Как оказалось, не М 4, а М 2. Фото ниже. Исправьте, пожалуйста
24 December 2019, 10:04:10
motor62, changed speed limit from 50 to 60.
02 February 2020, 09:43:41
02 February 2020, 09:46:35
motor62, changed object description from 'КОРДОН-М 4 (в спину)' to 'КОРДОН-М 2 (в спину)'.
02 February 2020, 09:47:02
Кордон-М 2, как оказалось, а не 4й.
02 February 2020, 10:59:40
спасибо
05 February 2021, 16:27:45
valur111, changed object latitude from 39.657480 to 39.657414
valur111, changed object longitude from 54.598349 to 54.598378
valur111, changed control area.
valur111, changed object description from 'КОРДОН-М 2 (в спину)' to 'КОРДОН-М2 (в спину) [190км 000м]'.
26 May 2021, 10:32:46
Штрафы приходят +1
26 May 2021, 10:33:03
26 May 2021, 16:29:40
Подтверждено +1
26 May 2021, 16:29:42
Подтверждено +1
28 May 2021, 07:17:41
28 May 2021, 08:59:35
Ваш штраф из парной точки в лоб https://mapcam.info/speedcam/point.php?idm=eMsh2z7cTFw Просьба выложить его туда
16 November 2022, 04:39:15
02 June 2023, 04:34:07
02 June 2023, 04:35:05
координаты камеры на снимках почемуто меняются
02 June 2023, 04:37:53
vini-tu, changed object latitude from 39.657414 to 39.657623
vini-tu, changed object longitude from 54.598378 to 54.598388
vini-tu, changed control area.
02 June 2023, 04:38:37
vini-tu, changed object description from 'КОРДОН-М2 (в спину) [190км 000м]' to 'КОРДОН-М2 (в спину) [190км 323м]'.
02 June 2023, 04:40:56
vini-tu, changed object description from 'КОРДОН-М2 (в спину) [190км 323м]' to 'КОРДОН-М2 (в спину) [190км 322м]'.
10 November 2023, 09:47:10
10 November 2023, 09:47:22
26 August 2024, 19:06:53
, changed object latitude from 39.657623 to 39.660553
, changed object longitude from 54.598388 to 54.597523
26 August 2024, 19:07:33
перенесли
26 August 2024, 19:07:46
11 February 2025, 16:57:11
27 March 2025, 09:15:51
, changed object latitude from 39.660553 to 39.660521
, changed object longitude from 54.597523 to 54.597489
