31 October 2026, 05:32:36
АРЕНА (ночная точка)
30 March 2019, 22:30:12
30 March 2019, 22:45:50
kenalog, changed warning start time from 0 to 19.
kenalog, changed warning end time from 24 to 7.
30 March 2019, 22:46:08
для мото в ноль -1
31 March 2019, 07:11:24
kenalog, changed object description from 'АРЕНА ' to 'АРЕНА (ночная точка)'.
31 March 2019, 18:52:55
yuryleb, changed warning direction from 265 to 264.
yuryleb, changed object notification distance from 400 to 500.
31 March 2019, 18:53:49
Совмещена по координатам и направлению с "дневной" точкой https://mapcam.info/speedcam/point.php?idm=zIMElK8xDdq
20 August 2019, 06:00:00
27 February 2020, 14:04:18
27 February 2020, 14:04:31
фото штрафа +1
27 February 2020, 14:04:34
фото штрафа +1
14 May 2022, 22:35:59
Измените скорость на 40, время с 7 до 19. Уже и штафы выложили,  а скорость все еще 60.
15 May 2022, 04:37:48
Есть дневная и ночная точки. Одна оповещает с 7 до 19, другая с 19 до 7. Ничего менять не надо, все настроено абсолютно верно. Проверьте в настройках мобильного приложения - Дополнительные настройки - Учитывать время объекта должно быть включено
02 December 2022, 14:36:48
Florian, changed object notification distance from 500 to 350.
28 July 2026, 11:21:14
28 July 2026, 11:21:16
28 July 2026, 11:21:18
28 July 2026, 11:21:59
29 July 2026, 10:22:45
29 July 2026, 10:22:47
29 July 2026, 10:23:53
, changed object latitude from 39.017957 to 39.017907
, changed object longitude from 45.021375 to 45.021383
29 July 2026, 10:44:11
выше -1
29 July 2026, 10:44:14
выше -1
29 July 2026, 12:32:06
