22 October 2026, 05:45:59
Кордон-М2
Russian Federation > Ивановская область
05 April 2022, 08:35:34
07 April 2022, 17:16:59
roma012009@rambler.ru, changed object latitude from 39.704507 to 39.704606
roma012009@rambler.ru, changed object longitude from 57.009501 to 57.009528
roma012009@rambler.ru, changed speed limit from 0 to 50.
roma012009@rambler.ru, changed warning direction type from Two directions to In a certain direction.
roma012009@rambler.ru, changed object notification distance from 500 to 400.
roma012009@rambler.ru, changed object view angle from 15 to 20.
roma012009@rambler.ru, changed object description from 'Объект добавлен 2022-04-05 11:35:27 с помощью MapcamDroid' to 'Кордон М-2'.
roma012009@rambler.ru, confirmed object added via Mapcam.info program
roma012009@rambler.ru, changed camera model.
07 April 2022, 17:21:38
roma012009@rambler.ru, changed control area.
roma012009@rambler.ru, changed control direction from Counter direction to In the back.
roma012009@rambler.ru, changed object description from 'Кордон М-2' to 'Кордон-М2'.
07 April 2022, 17:42:15
Похоже, перепутали направления контроля. В этом направлении должна быть в лоб https://yandex.ru/maps/-/CCUBr6fwcA Либо развернули с прошлого года. И надо сдвинуть метров на 15
07 April 2022, 18:00:36
roma012009@rambler.ru, changed control direction from In the back to Counter direction.
07 April 2022, 18:02:38
07 April 2022, 18:04:40
roma012009@rambler.ru, changed object latitude from 39.704606 to 39.704300
roma012009@rambler.ru, changed object longitude from 57.009528 to 57.009787
04 July 2022, 18:11:54
sademid51, changed warning direction from 327 to 326.
sademid51, changed object notification distance from 400 to 500.
26 January 2025, 17:48:27
Прошу удалить, столб пустой
29 January 2025, 06:26:49
Отсутствует -1
29 January 2025, 06:26:52
Отсутствует -1
29 January 2025, 06:26:54
Отсутствует -1
29 January 2025, 07:54:46
29 January 2025, 07:55:15
29 January 2025, 07:55:39
Добил -1
23 January 2026, 16:59:22
Ребята, прошу прощенья, подмена GPS была сильная, по видео посмотрел и сравнил с картой, эта камера на месте, работает.
23 January 2026, 16:59:45
Ошибочное понижение +1
23 January 2026, 16:59:47
23 January 2026, 16:59:50
23 January 2026, 17:01:36
, changed object notification distance from 100 to 500.
23 January 2026, 17:21:14
См выше +1
23 January 2026, 17:21:19
См выше +1
23 January 2026, 17:21:23
См выше +1
24 January 2026, 02:17:45
Для мото в 0 -1
19 September 2026, 09:41:31
Отсутствует -1
19 September 2026, 09:42:47
фото
19 September 2026, 09:41:34
Отсутствует -1
19 September 2026, 09:41:36
Отсутствует -1
19 September 2026, 09:41:55
19 September 2026, 10:08:41
Выше Удалил -1
19 September 2026, 10:08:45
Выше Удалил -1
