22 October 2026, 08:13:50
Пульсар СИМСК
31 May 2019, 19:10:22
31 May 2019, 19:11:03
Штраф [img]http://www.autosaratov.ru/phorum/attachment.php?attachmentid=484035
31 May 2019, 19:11:20
31 May 2019, 19:12:05
31 May 2019, 19:35:28
Timon34, changed object latitude from 45.985358 to 45.984974
Timon34, changed object longitude from 51.510245 to 51.510036
Timon34, changed warning direction from 243 to 245.
Timon34, changed object notification distance from 245 to 230.
Timon34, changed object description from 'Птолемей' to 'Декарт'.
31 May 2019, 19:35:56
мото в 0 -1
31 May 2019, 19:36:08
Подтверждено штрафом https://mapcam.info/speedcam/point.php?idm=ajC7OUzjmGj#comment_2401810 +1
31 May 2019, 20:02:14
Только штраф в спину.
31 May 2019, 20:05:56
Ошибка, здесь два штрафа
31 May 2019, 19:36:15
Подтверждено +1
31 May 2019, 19:56:36
[img]http://www.autosaratov.ru/phorum/attachment.php?attachmentid=484036
31 May 2019, 19:58:15
01 June 2019, 15:12:23
01 June 2019, 15:13:10
Спасибо автору точки!
13 August 2019, 02:54:49
21 October 2020, 20:07:45
сняли -1
21 October 2020, 20:07:49
сняли -1
21 October 2020, 20:07:59
25 October 2020, 14:31:50
Сняли камеру -1
25 October 2020, 14:31:53
Сняли камеру -1
25 October 2020, 14:31:55
Сняли камеру -1
03 December 2020, 11:10:05
по просьбе -1
03 December 2020, 11:10:08
по просьбе -1
28 July 2021, 08:57:01
Камеру вернули +1
28 July 2021, 08:57:05
Камеру вернули +1
28 July 2021, 08:59:38
28 July 2021, 09:04:57
youngstarr64, changed object latitude from 45.984974 to 45.980640
youngstarr64, changed object longitude from 51.510036 to 51.508778
youngstarr64, changed warning direction from 245 to 242.
youngstarr64, changed object notification distance from 230 to 223.
youngstarr64, changed object description from 'Декарт' to 'Автодория 3.5'.
28 July 2021, 09:23:26
28 July 2021, 09:23:30
28 July 2021, 09:23:33
28 July 2021, 09:25:24
2maxic, changed camera model.
28 July 2021, 14:17:35
28 July 2021, 14:17:44
08 September 2022, 11:42:16
сняли, рядом поставили на 40 -1
10 September 2022, 14:27:06
На Зеркалах Яндекса 16.08.2022 присутствует.
10 September 2022, 14:27:37
Компенсация необоснованного понижения рейтинга. +1
28 May 2023, 18:14:31
демонтаж, столб пустой, у гаишников не числится -1
28 May 2023, 18:14:35
28 May 2023, 18:34:36
Смотреть выше -1
28 May 2023, 18:34:40
Смотреть выше -1
29 May 2023, 01:16:13
29 May 2023, 01:16:17
29 May 2023, 01:16:31
Yoburger, changed object notification distance from 223 to 100.
10 January 2025, 19:07:26
10 January 2025, 19:09:01
новые повесили...
10 January 2025, 19:16:42
, changed speed limit from 60 to 40.
10 January 2025, 19:35:25
22 April 2025, 06:33:32
Отредактируйте пожалуйста объект. Кармы не хватает(
22 April 2025, 06:28:07
вернули, поставили на 40, штрафует +1
22 April 2025, 06:28:10
22 April 2025, 06:31:49
22 April 2025, 06:51:28
22 April 2025, 06:51:52
См. выше. Актуализация. +1
22 April 2025, 06:51:55
22 April 2025, 06:52:01
22 April 2025, 06:55:19
, changed object latitude from 45.980640 to 45.979819
, changed object longitude from 51.508778 to 51.508541
22 April 2025, 06:56:00
, changed object description from 'Автодория 3.5' to 'Пульсар СИМСК'.
23 April 2025, 08:35:19
Кармы не хватает исправить. Измените пожалуйста направление камеры, она смотрит в противоположную сторону.
23 April 2025, 08:55:14
, changed warning direction from 242 to 64.
, changed object notification distance from 100 to 170.
03 December 2025, 06:29:31
03 December 2025, 06:29:34
03 December 2025, 06:30:15
03 December 2025, 06:30:33
03 December 2025, 06:34:25
Штраф в соседней точке (ремни). Внёс доп.информацию.
03 December 2025, 06:35:23
, changed object notification distance from 170 to 300.
03 December 2025, 06:36:34
Добавил расстояние, 170м слишком мало.
