22 October 2026, 02:13:16
Бокс под КРИС в спину
17 June 2015, 15:21:19
17 June 2015, 16:41:46
Конкретно по этой точке: точка стоит не на дороге, скорость указана неверно, сектор маловат, дистанция, скорее всего, маловата для "встречки".
17 June 2015, 17:27:34
Ainstain, changed object view angle from 16 to 20.
18 June 2015, 06:36:50
silandser, changed warning direction from 175 to 180.
silandser, changed object notification distance from 527 to 800.
silandser, changed object view angle from 20 to 35.
18 June 2015, 06:37:08
По хорошему, точку лучше разбить на две
18 June 2015, 07:43:59
..., поставить НА дорогу и скорость...
18 June 2015, 17:28:50
Ainstain, changed object latitude from 30.654162 to 30.653915
Ainstain, changed object longitude from 61.667965 to 61.667975
09 November 2015, 17:49:04
deksven_dair, changed object type from  Portable Camera (trap) Portable Camera (trap) to  Рossible mobile police post. (note the layout or overtaking!) Рossible mobile police post. (note the layout or overtaking!).
16 December 2015, 19:11:48
valur111, changed object view angle from 35 to 45.
16 December 2015, 19:15:32
Ainstain, если эта засада ещё актуальна, поставьте парную точку,- со стороны Сортавалы (с севера на юг) укажите скорость 90 км/ч.
10 July 2016, 22:13:55
valur111, changed speed limit from 60 to 90.
10 July 2016, 22:14:22
В соответствии с реалиями.
11 August 2018, 23:10:18
silandser, changed object latitude from 30.653915 to 30.653797
silandser, changed object longitude from 61.667975 to 61.667099
silandser, changed object type from  Рossible mobile police post. (note the layout or overtaking!) Рossible mobile police post. (note the layout or overtaking!) to   .
silandser, changed speed limit from 90 to 60.
silandser, changed warning direction from 180 to 2.
silandser, changed object notification distance from 800 to 500.
silandser, changed object view angle from 45 to 20.
silandser, changed object description from 'Встречка' to 'Бокс под КРИС в спину'.
17 January 2020, 19:21:52
sademid51, changed object type from   to   .
18 August 2023, 08:39:20
18 August 2023, 08:39:27
18 August 2023, 08:39:33
18 August 2023, 08:40:14
Занулил в связи с неактивностью пользователя с возвратом кармы. Ящика нет уже давненько.
28 June 2024, 12:42:52
Карма давно не связана с рейтингом точки автора.
28 June 2024, 12:43:14
Выше Удалил -1
28 June 2024, 12:43:17
Выше Удалил -1
28 June 2024, 12:43:20
Выше Удалил -1
28 June 2024, 12:43:32
