13 November 2026, 12:12:27
For the past 24 hours: 59 objects added, 89 objects edited, 30 objects removed.
Орлан 2.0 [110км 468м]
25 February 2018, 15:45:29
25 February 2018, 15:48:20
24.02.18 была замечена тренога, после зеленой заправки в сторону Москвы.
Откорректируйте точку, если я вдруг неправильно ее расположил. Спасибо!
25 February 2018, 16:00:53
02 March 2018, 07:13:23
fantompg, changed object notification distance from 500 to 600.
fantompg, changed object view angle from 20 to 25.
fantompg, changed object description from 'Тренога' to 'КРИС-П М (111км)'.
02 March 2018, 07:13:47
09 March 2018, 18:29:26
Тренги в обе стороны перед заправкой. Замечаны 07.03.2018 (дата регистратора сбита)
09 March 2018, 18:30:13
Kowalski, changed warning direction type from In a certain direction to Two directions.
09 March 2018, 18:31:03
Треноги две, в обе стороны, - изменил точку.
09 March 2018, 18:31:07
09 March 2018, 18:31:12
09 March 2018, 18:31:50
Видел, добавлено фото +1
17 March 2018, 12:06:39
прохоров, changed object view angle from 25 to 45.
17 March 2018, 12:07:31
07 May 2018, 17:03:16
06:53 установка
06:53 установка
19 May 2018, 13:49:59
, changed object description from 'КРИС-П М (111км)' to 'Арена (111км)'.
19 May 2018, 13:51:56
31 May 2018, 07:04:15
31 May 2018, 07:04:44
pupok, changed camera model.
18 August 2018, 15:10:32
08 September 2018, 19:09:20
kenalog, changed speed limit from 110 to 90.
05 February 2019, 08:40:12
zigaman, changed object latitude from 37.483908 to 37.483734
zigaman, changed object longitude from 54.806318 to 54.806329
zigaman, changed warning direction type from Two directions to In a certain direction.
zigaman, changed object notification distance from 600 to 700.
05 February 2019, 11:30:46
kenalog, changed object latitude from 37.483734 to 37.483937
kenalog, changed object longitude from 54.806329 to 54.806336
kenalog, changed object view angle from 45 to 25.
26 March 2020, 13:45:07
На столбах висят стационарные камеры. В теме с описаниями камер я таких не нашел. Перед камерами стационарные знаки ограничения на 110. Первые два фото вид со стороны Москвы
26 March 2020, 13:45:18
26 March 2020, 13:45:36
Дальше фото со стороны Тулы
26 March 2020, 13:45:47
26 March 2020, 13:45:48
26 March 2020, 13:50:00
Камеры маленькие, длина сильно меньше диаметра столба.
28 March 2020, 14:53:00
28 March 2020, 14:54:41
Проезжал мимо на велосипеде, сфотографировал конкретно камеры. Увы, разрешающей способности телефона оказалось недостаточно, чтобы прочитать надписи на камерах.
31 March 2020, 18:33:05
Камеры здорово фонят, streetstorm их видит из далека
06 April 2020, 18:59:58
serezhka, changed object type from  Рossible mobile police post. (focus on speed!) Рossible mobile police post. (focus on speed!) to  Static speed camera Static speed camera.
serezhka, changed object description from 'Арена (111км)' to 'Астра-Трафик (111км)'.
06 April 2020, 19:26:29
Нашел в интернете "Астра-трафик", что-то не похожа на эту. У "Астры" крепление снизу, у этой камеры строго сзади. У "Астры" блок радара висит отдельно на металлическом кронштейне, у этой он приделан впритык к корпусу. У "Астры" есть антенна сзади, у этой антенны нет. И еще у "астры" на фотках нарисован дворник для протирки, которого тут явно нет.
06 April 2020, 19:27:09
Крупные фотки в этой теме чуть выше https://mapcam.info/speedcam/point.php?idm=asPBs1HHVtt#comment_2677017
06 April 2020, 19:27:11
06 April 2020, 19:29:02
Тогда крупней надо смотреть. И по точности их установить если здесь бываете.
09 April 2020, 15:47:12
Тренировался на велосипеде, захватил фотоаппарат помощнее и заехал к этим камерам. Фото см ниже, все совсем интересно :)
09 April 2020, 15:49:58
4
4
18 April 2020, 00:41:14
Отличный фоторепортаж, плюсанул. На ящике наклейка, на которой указано что это "Орлан 2.0" (исполнении 02), что означает раздельную конструкцию. Ранее известный Орлан был в (исполнении 01) моноблочный.
18 April 2020, 00:22:15
setpiton, changed object description from 'Астра-Трафик (111км)' to 'Орлан 2.0 [111км]'.
setpiton, changed warning start time from 6 to 0.
setpiton, changed warning end time from 23 to 24.
18 April 2020, 18:32:30
balabol.1974, changed object latitude from 37.483937 to 37.483972
balabol.1974, changed object longitude from 54.806336 to 54.806264
balabol.1974, changed object view angle from 25 to 15.
18 April 2020, 18:33:06
до подтверждения -1
18 April 2020, 18:33:11
до подтверждения -1
18 April 2020, 18:33:25
18 April 2020, 18:34:57
20 April 2020, 07:51:17
11 June 2020, 14:46:26
kenalog, changed object description from 'Орлан 2.0 [111км]' to 'Орлан 2.0 [110км 400м]'.
23 April 2021, 18:26:03
23 April 2021, 18:27:21
Скан штрафа выше. +1
23 April 2021, 18:27:25
01 November 2021, 20:44:07
silandser, changed object notification distance from 700 to 900.
01 November 2022, 11:33:59
01 November 2022, 11:34:10
По всей трассе (до съезда на Тулу) поставили ограничение 90!!! И в обратную сторону (со съезда на Тулу до Московской области) тоже.
01 November 2022, 11:34:23
Vorkuta979, changed speed limit from 110 to 90.
04 March 2023, 17:51:26
31 March 2023, 21:27:28
kenalog, changed speed limit from 90 to 110.
09 November 2023, 14:20:10
ilias_div, changed speed limit from 110 to 90.
09 November 2023, 14:20:28
В целях снижения аварийности  до 31 марта 2024 года ограничен скоростной режим до 90 км/ч на участке автодороги М-2 «Крым» км 108-км 177 292.  Новость: http://mh.rosavtodor.gov.ru/department/press-center/novosti/658411
03 March 2024, 19:03:11
02 April 2024, 17:33:16
05 November 2024, 19:58:23
02 April 2025, 05:53:34
02 April 2025, 05:53:48
С 1 апреля  на скоростном  участке автодороги М-2 «Крым» км 108 000 -км 177 292 в Заокском и Ленинском районах скоростной режим будет  увеличен до 110 км/ч.
https://mh.rosavtodor.gov.ru/department/press-center/novosti/712903
14 September 2025, 20:50:41
, changed object description from 'Орлан 2.0 [110км 400м]' to 'Орлан 2.0 [110км 468м]'.
14 September 2025, 20:51:00
31 October 2025, 15:42:28
01 April 2026, 08:14:19
31 October 2026, 16:56:18
